mikejdawson
- May 26, 2013
Been doing a bit of googling and got a bit confused.
2004 on a 53 plate R170 200 SLK Kompressor
There seems to be a general impression that these superchargers engines can be a bit on the noisy side at tick over, especially when hot?
Some people talk about a clutch mechanism that spins the supercharger up at above 2000 rpm but I can't see this type of mechanism. Actually, to be honest I'm not really sure where the SC actually is.
There is also talk of the variable valve timing mechanism which is apparently in the same area also being noisy.
When the engine is revved, the plastic air intake structure physically distorts as though its being sucked inside out so I'm assuming that its doing something!
There is what appears to be another air intake on the right hand side with what looks to be a MAF sensor?
It goes very well, noise disappears ( or can't be heard over the engine ), no smoke, clean oil.
All comments / advice / corrections gratefully received
Cheers
Mike
Cheers
Mike
