G8Master
Hi all,
My 2007 C180k has developed a fault were first thing in the mornings (especially when cold) when I first start the car the brake pedal is extremely hard to push, only when the engine has been running for 10-15 seconds am I able to push the pedal easily.
The brakes work fine after this point.
From some of the posts I have read it looks like I may have a faulty Brake Booster or possibly a defective Brake Boost check valve.
Before I condemn the brake booster, I would like to test/replace the brake boost check valve. Is this easy enough to do? How much do you think this would cost to get done at an Indy?
