poisas
Hello anyone has fitted that on the car for that fancy litle pshh noise ?
any info on that would be appreciated.
If you want to look like a t**t, just get a T-shirt with "I am a t**t" on it.
It'll be much cheaper
i mean why they dont work ?
ofcourse if they are loosing boost away= loss of power than its no sense i mean i just love to hear that sound it makes me happy so why could'nt i spend ~130pounds for it
It won't work because....
A blow off valve or dump valve is used on a turbo PETROL engine. A petrol engine has a throttle butterfly valve which blocks the inlet when you take your foot off the accelerator. When you do this, the pressurized air from the turbo has nowhere to go. Without a blow off valve, the back pressure can cause the turbo compressor to slow or stall. When you try to accelerate again, the turbo has to spin up to speed again which creates lag or a flat spot.
With a blow off valve fitted, when the throttle is closed, the blow off valve vents the boosted air so that the turbo compressor does not slow or stall so that when you press the accelerator again, the blow off valve closes and the boost is there instantly because the compressor is still spinning fast.
A diesel engine doesn't have a throttle butterfly valve to restrict the inlet when you take your foot off the accelerator, so the turbo does not slow/stall anyway.
so this won't work
http://www.ultratuning.com/en/product-7368-blow-off-valve-bov-kit-for-turbo-diesel.html
i mean if i loos my pressure while shifting gears, and engine is using this presure so i need to instal boost gauge to see what is happening in my intake manifold damit so where is that boost going ? to the cilinder ? so while accelerating and shifting i have positive pressure in the intake all the time hmmm.
sounds like a load of pshh:bannana:Hello anyone has fitted that on the car for that fancy litle pshh noise ?
You can buy diesel dump valve's.. they are electronically actuated.. cost around £200.. Forge Motorsport sell them.. to name one..
great explanation!!
I have a VTA BOV on my skyline and the noise really gets on my nerves , i wish i could get away without one but i tried and it doesnt work
I mean this E-clas avangarde with low as hell suspesion looks kinda sportish.
It was worth for me to make this threat and get knowledge about it. So NOW i know that i will never put any dump valve in my turbodiesel or any turbodiesel.
What i will do i will put a boost gauge and i will do a map mod with Schottky diodes to enchance sensitivity. and i will see what will happen
You could buy a 'supercharger' air filter from eBay.. adds 100bhp.. little fan instead a piece of rubber hose with a giant cone filter. :bannana:
