Heater blower motor
Piperbob3
Scotland
Mercedes clk 200 convertible
Hi
Any advice on heater blower motor it just stopped working.
Anybody know where this is located on Mercedes Clk 200 year 2000 ?
Its under the panel directly above the passengers knees below the glove box. 5 minute job to change but check first it could be the resistor that's gone not the fan. Also you can replace the brushes in the fan motor separately if its those. Did mine recently for just over £75 new fan and resistor, plenty on flea bay or ECP
Thanks Flango will have a look worked again in car the night then stopped after a we while could be the brushes.
I had no end of trouble with the blower not working. Turned out to be dirty contacts at the back of the control panel.
Did mine used to squeak took apart cleaned now quiet as a mute mouse, you could try just pushing base of spindle sometimes makes cleaner contact with brushes
