rumelk
Hey Peeps,
This time last year i was baking in my 124 with it's new matrix, and was awesome. However for some reason now it's quite the opposite. I have no heat what so ever!!
Background:
Last December, after eventually diagnosing my heating problem, which happen to be a old and blocked matrix, i changed the duo valve, control panel and the heater matrix, which had fixed the problem. FYI i dont have A/C.
Problem:
NO Heating! LOL
I've checked the input pipes from the duo valve which shows the water going in and the matrix return pipes which has hot water, so clearly the matrix is doing it's job, but the heat isn't getting into the cabin. I've advised that it may be the flaps which have not opened up hence the heat isn't getting into the car, but the dials are spining and you can hear it open and closing the flaps.
Is the flaps situation true? also are there any thermostats or sensors in the bulkhead that i should look to change/investiage?
Any help would greatly be appreciated
Background:
Problem:
NO Heating! LOL
