Do you mean the "comfort connect" cable with eyelets to allow you to permanently leave it on the battery? It is actually since then that I've had problems charging it. The other different thing I did then was a full recondition, which I'd not tried before.
I took the comfort cable out on Sunday though in case it was shorting. Still wouldn't charge. Unless it's damaged the battery. Or a red herring and nothing to do with it![]()
I'm using the clamps now in the kitchen. 2nd attempt at charging has stayed at step 3 for a couple of hours, so it seems to be happier currently. Go figure ..
I got the comfort indicator panel installed in mine, no issues with this. It was the CTEK 2.5m extension cable that was causing my charge problem, once removed the battery was charging properly. So I ended up extending the 3 pin wall plug, happy days.
FYI - If you are going to use the recon. mode, disconnect the car battery terminals and connect the CTEK charger directly to the battery. This is from the CTEK website, just easier to play it safe.
Does the battery have to be disconnected from the vehicle when it is being charged with a CTEK charger?
No, CTEK chargers cannot damage sensitive electronics. So, you don't have to disconnect the battery from the vehicle! However, you should take extra care when using recond because the voltage is 15.8V. Most manufacturers consider everything to be fine as long is voltage is below 16V and CTEK is under that limit by a good margin, even during recond. Note that the service life of some components is shortened by high voltage. A rule of thumb says that a light bulb's service life is halved by increasing voltage by 5%, but this is normally not any great danger. If you have any sensitive electronics for which the manufacturer warns against high voltage: disconnect them!
