Help please.
Mickyh7
Leeds
SLK250d
2014 SLK250d
Hi, I was on the motorway this morning, stopped in a traffic jam, dropped my side window for some air.
20 minutes later road clears.
Side window stuck down.
Messed about jiggling the switch (which worked when the passenger side switch went).
Nothing.
I'm at hospital with my mum in Newcastle, I'm based in Leeds!
I've taped a bin bag over the door hole.
I'm using a taxi now.
No idea when I'll get out of the hospital,
Any one know where the fuse is located? I have no tools, and facing a 130 mile journey tomorrow in the cold
Thanks in anticipation.
Hopefully this will help. Good luck.
Best wishes for your mum
Maybe call out Mobilo if you have it or AA/RAC etc.
Would I be correct in thinking the 'Door Control Module' fuse would cover the electric window?
Fuse28 25amp
Check to see if any incandescent lights go dim when you operate the switch. If they do, it’s stuck rather than a wiring/module failure.
Also pressing the window button vigorously may help.
