...........Meanwhile. I tested the car. 0-60 with everything switched on Air, lights, radio ,rear window etc =19 sec. Then I turned off everything 0-60 16.3 secs which is what the book says it should take!! Then start checking the car over. Open up airbox to discover bits of leaves, oil and muck and an airfilter that has never been changed (Yes it is dealer serviced!!!) Then a quick drive down to Team Drive in for a Mahle Airfilter (£9.99). Clean air box, put in new filter and back to test the 0-60 which is now 13.2seconds ie 20% faster than Nissans figures and 30% faster than last night!!!
My wife thinks it drives like new again, and if she needs that extra bit of power on the motorway then all she needs to do is press the turbo button as suggested by spike (ie the Aircon OFF button).
Result. thanks Spike!
