DexterML
Hello all
W163 2001 2.7 CDI ...as per the title, the engine just died as I was accelerating out of a roundabout. It refused to fire up again. It eventually fired up again after about 30 minutes and has been starting ever since. (half tank, not quarter in)
This is serious, I don't trust the car. This was after I returned from the repair shop having new calipers fitted and sorting out the Coolant leak.
Although the news were grim, massive corrosion underneath, All brake lines, both rear sills, O/S/F sill corroded, Front chassis heavily corroded. - I still don't know how the car went through an MOT last October, I mean this is beyond my brain's capacity to comprehend- I was pleased I could finally drive it. As I was driving it around, and as I was coming out of a roundabout, it died. It just died. It wan't the battery, as it kept trying to start it. I looked both online and on the fuse boxes to find the fuse for the fuel pump, but I couldn't find one.
Didn't matter, because as the car was on the flatbed, I tried once more, I don't know why, and it fired up. It has been firing up ever since.
Then the key wouldn't come out of the ignition cylinder.... had to try starting the car about 10 times before it released it.
Also during the drive, the anti spin triangle came on, after a left turn and I guess was trying to do something with the brakes...not sure because I could hear something happening, but it didn't affect the speed of the car.
After that the BAS/ESP light came on, which was on when I got the car, but had been off for a few days ( i wasn't driving the car, I was just starting it, to keep the battery level up)
I mean it is really dangerous having the car just dying on you while you are driving and you are in the middle of the road.
Has anyone got any ideas before I just scrap this Frankenstein car ?
2001 ML270 93500 miles
coolant warning light..................................... fixed
Coolant leak.........................................................fixed
Radio not on......................................................fixed
Lamella sunroof not fully opening (opened twice, small gray plastic bit broke off, not it wont' fully open, erratic operation)
BAS ESP light on (resetting, removing K25 etc, doesn't do anything for it)
Massive water leak, entire floor is soaking wet, even the glove box (!!?).
Driver's lock doesn't turn................................................................................................................fixed
Seat controls don't work
Brake switch maybe on the way out
FOBs don't lock/unlock (new batteries) ................................................................................(fixed, one works now, the second starts the car, but won't synch)
Brake discs need replacing all around
Front calipers seized.......................................................................................................................fixed
bonnet struts broken (ordered)
Boot struts broken.........................................................................................................................fixed
running board only on one side
broken front bumper (AMG style ?)
Rust around tailgate handle
Rust under the doors.
o/s/f lower ball joint needs replacing
o/s/f rack gaiter needs replacing
All brake lines corroded
Both rear sills corroded
0/s/f sill corroded
Front chassis o/s and n/s heavily corroded.
faded bonnet
rear bumper off its clips
rear wiper jet not working
0/s/f sill corroded
faded bonnet
