The time has come to call in the experts, so here is my little weekend teaser for you all...
I've read many posts on this and other forums and spoken to two mechanics trying to solve a problem with my 300TE-24 and would appreciate some new ideas.
The Car:
- 1990 300TE-24, M104.980 (3.0 litre, KE-Jetronic with MAS unit, non-biodegradable loom)
- Airbags, LSD, ABS and cruise but no ASR (so mechanical throttle)
- c.200k Miles/315k KMS
- Good service history, mostly at main dealers
The Symptoms:
- Slightly slow cold start leads to even, correct warm up cycle. After 30 secs or so the idle rises to 1,500 or so and then continues to increase as the engine warms reaching c.2,000 if left to its own devices.
- Restart at operating temperature brings on correct, even idle (c.700)
- Restart at less than full operating temperature brings on correct, even idle but it will creep up as the engine warms further
- Unplugging and replugging idle control valve leads to correct, even idle
- Fuel consumption slightly high, possible slightly rich mixture (no analyser but from smell and slightly excessive amounts of light exhaust smoke), oil consumption normal, power seems good.
- Basically the idle control valve seems to be more active then it should with a warm engine.
What I've Tried so Far:
- Idle control valve looks reasonably new and seems to open and close well (revs instantly drop once it is unplugged).
- Voltage OK to idle control valve
- New genuine MB thermo-temperature switch/sender fitted
- No leaks found around inlet manifold (hoses look good and all joints and hoses sprayed with brake cleaner, no change in idle).
- New genuine MB injector seals fitted (all three parts: O-ring, seal and holder)
- Cold start valve tested, functions correctly at start up and shuts off with no leaks
- New genuine MB camshaft sensor fitted
- Air meter system cleaned and seems to move well
- Throttle mechanism cleaned and seems to move OK, cruise works fine
- MAS unit was replaced with new genuine MB part in 2004
- OVP replaced at some point, not tested but no ABS light etc to indicate problems
- At this mileage the car must have had a head gasket done in the past, no signs of usual oil leak at rear or oil in water.
Remaining Suspects:
- Perhaps the ECU, I've not been able to find a correct good one locally to test yet. Does anyone have experience of this ECU failing, perhaps with symptoms? The mechanics say they rarely see failure of this unit (NB later M104s are another type).
Thanks in advance, while I can work around this problem it would be nice to have her running perfectly...
Harvey
PS apologies for the long post, I hope that the detail is relevant
