Justintyme
The epoxy goes straight on the bare metal after welding in the section?
Its a strange way to do it OK....Normally, all panels should be painted at the same time ( at least when I was doing it anyway..) because there can be minute differences even between coat's of the same mix, but more so if its a metallic colour.. But I guess Rob knows what he is doing, so hopefully it will be OK. They look great by the way....any time you can see your own reflection in the finish, thats as good as it gets.. LOLFirst Batch of Volvo panels are back from Rob. I expressed some concern that he was painting some bits to final finish before the shell of the car, and whether there would be problems with matching. I felt a bit of a fool when he laughed and said it would all match fine. He said he'd do it again if it didn't match, so I'm happy really I guess!
The finish is flawless. I'm slightly concerned now that I might have gone down a path where the end product is too nice to drive. I think at the end this car will be moving on, so hopefully I won't need to fret too much about stone chips and the like...
Couple of pics.
Bonnet mirror...
Is It ??IF ITS AN ORIGINAL 356 SPEEDSTER IN GOOD NICK ITS WORTH £100K+
What condition were the manifolds in?Mildred been a little poorly since a run out in the blistering heat a few weeks ago.
Not an overheating problem, think fuel was vaporising in carb.
Quick strip down of carb. improved matters but not enough.
Stripped the inlet/exhaust manifolds off to fit new gaskets.
Changed Coil, plugs, condenser, cap and arm.
Newly sourced New Old Stock carb. ready to be fitted.
Getting one with the Auto choke mechanism is tricky.
