Delayed response here. I had to wait until the weekend to get a car battery and alternative work around. Just to recap that it didn't work using a car battery to connect to terminal under the bonnet. I assume it is because I only had the negative point disconnected in the boot.
So how did I solve this problem to get the boot open. Get advice on this as I did it as last resort and offer no support or fault for problems resulting from doing the following, but it worked for me. I connected two 6v batteries in serial to give me 12v, normal consumer batteries not car (to avoid blowing the system and/or me). With two wires red for positive and black for negative, I added a croc clip to the negative, and left positive stripped. The other end had connectors for terminals on battery. I took out the fuse for the central locking (27), stuck the stripped wires of the positive into it, and connect to positive on battery. I then clipped the negative crop to the engine block, and attached to neg of battery.
Luckily this gave the central locking juice and I could open the central locking with the key fob. Delighted this worked for me, but again make sure you know what you're doing I took advice from a friend of my Dads who organised the battery and even put a fuse in it for me.
Anyway back to my original problem, the flashing rear view mirror red/green lights. Disconnecting the battery didn't solve it, it was disconnected for a week. A few auto electricians didn't want to even know about it as too much trouble and all directed me to the Merc dealer in town. I called in this morning and without seeing the car they think it'll cost upwards of €1,000 to fix. They have come across the problem before and said the following will need to be done:
- New mirror (he said that's where the immobilizer is?) €350-€400
- New key (seems to be standard replacement for that problem) €250-€300
- New key barrel maybe needed (not sure why didn't explain that part) €250-€300
- Including labor costs of all this adds up to about €1,000 to fix a 1995 car.
So I've decided to bring the car to a garage I know who specialize in fixing cars using parts from scrap yard, as dealer will only use new parts. I will ask them to look and it and see what they think and get all the parts above from a scrapped C-Class and see if it works.
If it can't be fixed for under €700 I'll scrap the perfectly good car with almost new (3 months) tyres, light lends and exhaust.
