nmacc
Hi folks,
I'd been having some very rough-running problems for a while, but couldn't track them down because the problem was intermittent.
It turned out to be caused by perished insulation on the leads to the MAF, as you can see:
Subsequently I removed the MAF connector. Since it's moulded on I had to saw off the top, but as you can see, the insulation failure goes all the way to the pins:
Anyway, on Saturday I called to a local independent MB specialist to see if they could read the codes. Instead the mechanic moved the MAF wiring and the engine ran smoothly. Excellent!
So I moved the MAF wiring, and the loom went up in smoke! Now I have a bigger problem:
It's also quite possible that all of that melted insulation has resulted in a blown ECU, but I won't know that until I've made some sense of the charcoal.
I've begun the rebuild, but I've reached a tricky point. Although I've reconnected most of the damaged cables, I'm left with four red/blue wires. Actually two are red with a blue trace and two blue with a red trace; at least that's how it looks to me.
Two of these definitely went to the OVR; pin 6 I think, but I'm not sure where they went from there. One of the free ends in the loom goes (I think) to pin 38 on the ECU.
Also, there was a 2-pin connector supplying power and ground to the MAF. There's not much left, but I suspect that the power was on one of the blue/red leads.
What I'm getting at is, does anyone know if all of these blue/red leads are electrically identical? If so, I should be able to connect them together.
Of course the ultimate resource is a diagram of the engine loom. The Haynes manual is quite good in this respect, unfortunately it doesn't cover the 220.
Any assistance would be much appreciated.
Thanks,
N.
Thanks,
N.
