Iain
Just purchased a C200 sport auto on the 'W'.
It has the usual 3 button IR remote key. When placing the key in the ignition, I cannot hear a click as is normal.When turning the key to position 2 all dashboard warning lights illuminate as normal.Then into starting position 3. Nothing. Starter motor doesn't crank and dash lights do not dim as would normally be expected. Also the steering lock remains on and strangeley the key does not hold in the ignition,it falls out.
Anybody come across this problem before or something similar?
All suggestions gratefully received.
