Inside edge...
renault12ts
MB Club Veteran
2005 W215 CL500.
...of the offside front is worn to slick. The other tyres are all wearing evenly and were replaced at the same time . They have now done c.14,000 miles.
So, what's the verdict? Thanks.
Check the suspension for play and the lower arm bushes for splits.
The car was MOTed this evening, since I first posted. Passed with no problems. So the ball joints and bushes etc are fine. Must be a set up problem. The test ( in NI) is very rigorous and if they didn't find it, it was not there.
therefore the setting must be out.
too much toe out on that front offside.
but I would have suspected the wishbone bushes too - they are very difficult to check with the spring and shocks in place as there is to much tension to make them move.
Have a look at the castor bush by levering it over. If they are original I bet they are split
