I developed this fault today Intermitentley A loud buzzing occurs when driving. It increases in pitch with revs. I have located it to the very top on the engine, by the red part.
It sounds like it's engine speed related so must be part of the main mechanicals.
Get this checked out as it could be something like a loose timing chain or broken chain guide.
If you're really lucky it might just be the top cover is loose and vibrating, but I doubt it.
Smart ForFour AMG Black Series Night Edition Premium Plus 125 Powered by Brabus
If it is a bearing...
I believe dealers only replace the entire supercharger, and won't replace only the bearing. I've read of people doing a DIY replacement in the US, using an off-the-shelf bearing for the C32 - can't imagine it's much different for the other engines. Apparently some have had local repair shops complete the whole job for $100.
Try the US forums like www.benzword.org and have a sniff around.
It seems strange that it is the Kompressor because there was no loss of performance etc. And no warning lights came on. There was just this bloody annoying noise.
A new development, after exploration it was found to be the altenator. The shaft and front bearing assembly had dismantled, its being refurbished as we speak.
