KLP 92
I'm having a problem on a late 2002 C270 CDI. The A/C has been playing up for a few weeks and will work intermittently.
So far i've had the system regassed twice, first to top it up and second time to ensure they correct amount of gas was in there. The system is losing any gas, after 2 weeks the same amount of gas was still in the system.
I checked on MB Star diag to see if there are any falut codes. The onky one on there was low refrigerant pressure, which wasn't a current fault but a stored one. Deleted the faults codes and the sytem was fine for a day.
The A/c worked all day yesterday but stopped working again today in the morning and is working fine now. The worst possible type of fault when it comes to diagnosing!
Now i've phoned a few chaps for advice, i've been told it could be a sensor on the side of the heater box behind the dash, resluting in a dash out job. Is this a possibility?
I've rung MB today and they can't find any pressure sensors for the A/c, only a temperature sensor located at the bottom left of the condensor.
Any help/suggestions will be more than welcome.
