intermittent electric windows
Gillsfan
Somerton, Somerset.
Ford Focus/Reliant Scimitar
Hello
I've had a problem with the passenger side electric window on my X reg vito 110 CDI since I got it last September passenger side electric window only worked some of the time. The drivers side was ok so I've been putting off investigating. with the current hot weather I've decided to have a look. I found and repaired damaged wires in the rubber tube thingy that's in the gap when the door is open (does that make sense my minds gone blank for the correct term) I have read that it is a common fault. No change if I 'jump' a earth into the blue or black wire (it was a few days ago I could have got the colours confused) then the window will go up or down depending on which wire I earth. I thought it was a problem with only the passenger side, but after check the drivers side i found that the previous owner had put 2 wires in to make the drivers side work so I assume that the problem effects both sides. I've run out of ideas I haven't got a wiring diagram and I'm not very good at modern car electrics, I'd be very grateful for and help
If I got the correct diagram, you should not be able to wind windows up and down by grounding one or the other wire that goes to the window motor. The wire colours are neither blue or black but have multiple colours.
I guess you did not check the switches, a bit difficult to do it without the wiring diagrams. I could email the diagram but I'm afraid you cannot PM your email address yet, need more posts.
Hi yes the switches are ok, like I said the drivers window works but that has extra wires added by the prevoius owner. I swapped the switches about to check them and they all work on the drivers window. the diagram would be great my eamil address is [email protected]
One more post needd to be able to pm so here it is.
