mr tibbs
Hi all
We have an E320, S210 2002 and it has been running great until the other morning when we jumped into it and started it. The motor turned a couple of times then there was a whizzing sort of sound and the motor stopped cranking. I turned the ignition key to Off and there was a slight clunk and the starter motor stopped rotating. I retried the key and it started properly?
Since this happened it has done it a half a dozen times and I am thinking I should replace the starter motor before it lets go and leaves us stranded somewhere.
Is this fault likely to be the starter motor gone daft or is there some other component that would cause this fault?
Looking forward to your replies
TIA
Keith
TIA
Keith
