Use a proper MB number plate holder.
That is screwed to the car in the proper non-rust mountings
Complete opposite IMHO; Drilling holes into plates simply encourages water ingress which delaminates them and makes them look grubby from the inside out - often in a matter of months. Attaching by sticky tabs completely avoids this. Also sticky tabs do not rust unlike screws and if correctly applied will need some serious force to remove. Last time I removed a plate held on with sticky tabs the plate was destroyedAnd dare I point out that plates retained by screws (as MB intended) tend not to succumb to the weather and other vagaries...
No I think it was a plate which self-destructed if enough force was applied around the outer edge, leaving the letters mostly visible on the car (and still attached) but the outer frame missing.Isnt there some adhesive based system shown on fifth gear which stops plate theft like this? I think it's tougher than sticky tabs.
I Use the surrounds, either the black MB one or this style.
Then the number plate slots inside and is secure. The Front of the B class like the E class is quite angular so awkward at first to get it to fit.
I like this method to me it looks quite neat?
and the back one..
I'm thinking you could get fingered
If the sticky tabs are so strong, how do you get them off the car without damaging the paintwork?
Screw standard MB plate holders to the car, glue plates to the holders.If the sticky tabs are so strong, how do you get them off the car without damaging the paintwork?
Or fit it upside down!
I think 4 pages on this is quite enough.
None of us were **THERE**.
At the end of the day, the police are there to enforce the law which requires that cars have number plates on them. They get told alot of stories every day and most of them are unlikely to be true so I think that we can forgive them for being a little sceptical.
Life is far too short to imagine all the ways in which retribution could be legally achieved. My suggestion: fit the plates and if you have their details ring up the nick and tell them you've done it. Otherwise forget it and move on. Life is **UNFAIR** sometimes and far too short to worry about this.
