OP
OP
Deleted member 65149
Guest
Excellent advice. Annoyingly the engine oil was changed just a couple of weeks ago.Not really. The de-NOx storage catalysts are temporary 'buffers' that hold enough NOx during lean-burn operation that can then be processed at times in the journey when the engine is under enough load to warrant a move back towards Lambda <=1, in other words when there's less oxygen in the feed gas. This will happen pulling away from the lights or going up hills in the normal way. Lean-burn operation will most likely be limited to steady light-load conditions.
The main problem for the NOx sensors in your case is I think that the majority of your journeys are short urban trips.
I don't know whether the additives you've listed above perform as per the claims made by the manufacturers, I've not used acetone before as a fuel additive. The dose rates they mention are quite high (500ml/15 litres) and it's worth considering that some of whatever goes in the fuel also ends up in the engine oil/sump. So if you do end up trying it out, it might be prudent to change the engine oil afterwards too.
