- Mar 11, 2013
- Location
- South Bucks
- CLS63 SB, SLK55, CLK350 'Vert, Triumph Sprint (Bike not Dolly...),
TBH, what I think we have here is a combination of the Placebo Effect and Snake Oil.
If you want to spend a tenner to put more additive into your fuel and are happy that it’s money well spent, hey no worries. No skin off my nose. Just be aware that having too much additive can create it’s own problems. More isn’t always better, so just be careful not to overdose. The blurb from Liqui-Moly says the treatment is for 70-litres.I can't be ****d either because as I say it's a debate that will rage on forevermore. Maybe a couple of people go try it and see what they think? The science behind what's shown in the video is undeniable I guess to a point, and there are, as said, many many variables to what engines would respond well to the additive and which won't. End of the day just keep your tenner in your pocket if your certain it's snake oil. A lot of these things that we call snake oil DO clean injectors and stuff over time, the benefits may be almost negligible though in many cases.
I doubt very much if there is significant room for improvement on V-Power.Aa a regular Shell V-Power user, my question is whether Liqui Moly can do better than Shell - I am assuming that Shell put into V-Power everything they know, and it would be rather embarrassing for them if their best fuel can be easily improved by an additive.
I am not denying the benefits of fuel additives in general, I am just wondering if the fuel I use - Shell V-Power - can actually be improved by an additive.
Jet A1 or the 100 Octane low lead for our aircraftI doubt very much if there is significant room for improvement on V-Power.
Nah. Someone else tops off the tanks on return to baseDo you have misfuelling-proof nozzles for those as well?
I don't run on either of those fuels,I meant light aviation in general, not you personally.
Or have I missed the point entirely?
Would a reputable German company lie and sell a product that was not capable of achieving what it claimed?.........
Have any of you actually TRIED IT?
I was referring to the fact that Jet A1 is kerosene and 100 0ctane is petrol, that's all; two different fuels, like diesel and petrol for cars.I don't run on either of those fuels,
More than possible after an excellent lunch and some additional sampling of the current wine stocks
Most light aircraft have fairly crude fuel filer caps that simply twist on and off. Occasionally they may have a key lock.
Jet A1 I believe is fuelled via a specific safety nozzle that prevents flow until the mechanical contacts are secured and locked.
Both operations are also carried out with earthing cables connected first.
I made no reference to anything made by Liqui Moly other than their petrol additive. I accept that it's probably an octane booster, but if you are adding it to V-Power and believe that you are getting any benefit, well, see posts #79 and #81.Thanks for coming to my aid, there's just a lot of people that are saying it's nothing but snake-oil. I think they are a great brand, I haven't even heard my timing chain since I used one of their oil additives and my oil temps are always lower
You would expect it to be clean anyway after just 40,000 miles, ordinary Tesco fuel still contains cleaning properties, isn’t that part of the fuel standard ?No. But I have used Redex for many years (with regular fuel). When removing the injectors rail on my car that did 40,000 miles on petrol with Redex, the injectors were super clean - in fact they looked new. That's all the proof I needed - fuel additives do work.
What oil additive has Mercedes recommend for their engines ?since I used one of their oil additives and my oil temps are always lower
