Nicebutdim
- Jul 5, 2017
- E320 cdi avantgarde 2007. Honda Goldwing GL1800. 1975 Norton 850 Commando. 1975 Suzuki GT750.
2007 E320 cdi. 75k miles
Recently been hearing a patter front O/S when driving on rough road surface.
With the front jacked up and with energetic upward lifting of the front wheel I was able to hear a knock from the upper part of the suspension strut. I thought either top strut mount or worn out shock absorber strut.
I removed the suspect strut today. With the strut removed from the spring I found that If I push the damper rod into the strut body it pushes back as if it were spring loaded so much so that it actually makes a metallic smack sound as it hits the end of its travel when fully extended.
I would have expected the damper rod to be very difficult to extend when compressed and would only return very slowly to its fully extended position.
Can I safely assume this strut is knackered?
