jdrrco
- Mar 6, 2006
- Location
- North Yorkshire
- X218 CLS500 AMG BlueEfficiency Sport Shooting Brake - name almost as long as the car... & W202 C200
Google "car delivery company". Loads of them out there
If you decide to tow it on a trailer, make sure that you have something with surge brakes
Ask on Shipley
I got the car home It's at a local garage.
If that bolt hole has been drilled out , there is a danger it might have gone into the water gallery below ...Well the car is now at a local garage.
First impressions from my mechanic are sadly not that promising. The old injector is lying on the floor inside the car along with the bolt which holds it in. The threads on the bolt are stripped and the hole has been drilled out so the bolt falls right in and rattles about, no idea why, the mechanic said he wouldn't be surprised if it's been drilled right through, id imagine that would be easy enough to check, but the garage was extremely busy with other cars this morning. The other thing my mechanic couldn't understand is why the car had broken down in the first place, claiming that even with a bad injector it should have still been driveable, he thinks the high pressure fuel pump is more likely to have failed. Not sure how much this all might cost, the car is an 05 e270 Avantgarde.
Andrew
There are professional car transporters moving between Ireland and England every week. I think that it costs about €4-500 per vehicle, why don't you contact one of these services? Try Google :- Vehicle transport services UK to Ireland.
I have recovered many vehicles, but in this case, I would only use a tilt-bed truck, with tie-down straps etc. Would not even think of using a trailer in this case.
