JL Audio 5.25 XR Component Set Speakers
JOM
Kent
Looking for a Merc....
£125
Slight damage to one speaker - see photos
5.25-inch (130mm)
2-Way Component System
When you set out to build the very best, you work with only the best. That's why XR component woofers are built with suspensions and cones from the world's best manufacturer of such parts: Dr. Kurt Muller and Co. These parts are expensive, but they also represent the best the world has to offer and are integral to the incredible sonic quality and consistency of the XR products.
The long-throw component woofer features a mineral-filled, polypropylene cone body with a butyl rubber surround and a highly optimized motor system, delivering stunning midbass impact and midrange quality.
The tweeter is a neodymium magnet, ferrofluid-cooled, 1-inch (25mm) aluminum dome with a synthetic rubber surround that damps unwanted ringing for smooth, non-fatiguing output. The component tweeter features JL AUDIO's exclusive RSR mounting system, permitting precise alignment after installation for optimum performance.
High-end, programmable crossover networks with premium polypropylene capacitors,premium inductors and solid-state tweeter protection round out the package. Crossover networks can be programmed to 15 possible settings (3 midrange presence settings, 5 tweeter level settings). The crossover networks are attractively presented in a smoked acrylic case that complements any installation.
This exceptional component system will recalibrate your reference standard for automotive sound.
Description: 2-way System: 5.25-inch (130 mm) Woofer; 1-inch (25 mm) Aluminum Dome Tweeter, Grilles Included
Power Handling: 60W Continuous
Recommended Amp Power: 25 - 125 Watts
Efficiency: 89.5 dB @ 1W/1m
Frequency Response: 53 Hz - 25 KHz ± 3 dB
Frame O.D.*: 132.3 mm
Grille Tray O.D.**: 152.6 mm
Magnet O.D.: 72 mm
Frontal Coaxial Tweeter Protrusion***: N/A
Frontal Grille Protrusion****: 21 mm
Xmax: 1.5 mm
