Vincenzo13
Hi all my key fob just went dead!battery light flashes,infrared light works,but nothing?yet my spare key locks unlocks and starts car?any ideas cheers
Yes Chris spare key works,so obviously key?but how do I get old key to work?any ideas appreciatedTry with your spare key; that should indicate whether or not it's a key issue or something else.
Hi it’s a 58 plate c class 2.2 diesel,I’d pulled up outside my house and pressed the lock on remote,nothing,so put the key in ignition again nothing?went and got my spare key and everything worked!the bit that holds the batteries I took out and that worked in my ‘spare’key?so it must be my original key?baffled I am cos there was no warning?The OP has provided a reasonably good description about the problem but still some details would be useful. Which car is it, a C-class as in the signature but which MY? Keys are completely different on the current C compared to older models. Is it a Keyless Go key? The misbehaving key does not open/close door locks, neither starts the car?
Assuming it is the 204 series type "normal key" and does not operate locks, neither starts the car with the key in the ignition lock, the problem indeed sounds weird. It isn't the IR led as the OP has tested it. It isn't the power coil as it would not affect door locks, just starting the car. It does not seem to be a stuck key switch as the OP would have observed that when testing IR. Battery is not needed to start the car although it seemed to be OK. If the key coding was corrupt, the car should give a "wrong key" warning at the cluster (W204 and newer).
