GazCaff
I've got a slight problem with the kickdown switch on my CLK. I've found that to get a "full" kickdown using the switch I have to really stamp on the pedal. At first I thought that the CLK 320 was just a bit different to my old C250 in the way it behaved as if you floor the pedal it will usually drop a gear anyway. But I have confirmed to myself that the switch isnt always working as it will not trip out the speed limiter all the time, unless you really mash the pedal.
I think the kickdown switch just needs cleaning to be honest, but I am unsure if it is possible to remove it in situ to give it a clean. Can anyone give me some pointers?
I'm almost positive that it isn't a MAF or ECU issue as the engine is in rude health and will give full power when floored, but it just doesnt always drop in to the lowest gear available.
