hi, i just wondered if any one can help, i have a CDI 220 2003, i have found that diesel is leaking from what i think is the fuel pump, is the pump at the front of the engine? when i start the engine i can see a few drips coming from the bach of the pump but as it is tight its hard to see where exactly, i dont think its coming from the fuel pipes. im thinking of removing the pump and replacing the gaskets, is this a hard job and has any one got any tips. there seems to be 3 small sections bolted onto the pump, 1 at the top an the other 2 at the bottom corners, im thinking the seal has gone in the 1 on the bottom left corner, so if i get the pump off i plan to change the seals in all 3. is there any easy way to remove the fuel pump. thanks. thanks for your help on changing and the injector seal. 4 months on and its still ok
