- Sep 27, 2016
- Location
- UK
- Tesla Model S, Model 3 LR, Model X /// Previous: Jaguar XFR, Mercedes E320 CDI, C32 AMG, CLK 320
So, you're saying that there's no difference in battery performance between an EV that is only supercharged at 100+ Kwh, to 100% full.....
And battery performance for the little Tesla 3 which is only charged on a granny cable to 80% ?
Sure about that?
Because if there's no difference, why do all EV manufacturers emphasise only charging to 80% "for daily driving," and warn about continued dependence on very high rate charging.
(To this day, I still don't understand why people go on and on about the benefits of supercharging when for the average motorist with her own driveway, driving 8 - 10,000 miles a year aka 160-200 miles a week, a granny cable is going to be more than enough to meet her needs most of the time)
This is an interesting point and one I feel qualified to answer.
First of all - the higher charge rates are only at lower SOCs - as the SOC rises the BMS lowers charge rate, and multiple long term studies have found that (at least in Teslas case) frequent DC charging has no significant effect on battery degradation. Teslas advice is to charge in the most convenient way for you - I know many drivers who only supercharge as they don’t have home charging. The main killer for batteries is heat - so you only get the max charge rate in ideal conditions, when the battery is up to temperature etc… the car will start to pre-condition the battery when you are en-route the a supercharger, and if you still haven’t reached optimum conditions it will cap the rate at the start until said conditions are reached. The BMS is extremely good at what it does.
The newer LFP batteries can also regularly be charged to 100% with no negative effects, however even non-LFP can be charged to 100% with no issues for long journeys when needed - it’s just advised not to leave them sat at 100% SOC for long periods of time.
I’m not disputing the fact that using solely slow charging is the best solution - but who actually cares? It’s a car - I would always say use it in the most convenient way possible. Home charging is great and the best way - but if you need to travel long distances just plug it in at the rapid charger and get on with it.
Typed whilst supercharging at 120kw…
