The engine can cut-out (usually at a junction), when switched off and back on again is fine! Last time it did there was a fairly loud humming noise from the fuel pump. This might just be because it was re-priming after the cut out though?
This is very intermittent, most drives it does not happen (which makes diagnosis a PITA). I have already changed OVP, fuel pump relay, ignition leads/cap/etc. Vacuum pipes are all in good order.
Any thoughts very welcome. I am absolutely lost and don't have much faith in a garage diagnosing it because its so intermittent
