shanksy
Hi all, I recently had a problem whereby oil was leaking into the coolant.
No water was getting into the oil fortunately.
It got to the stage where the engine was overheating and the coolant was nothing but sludge so I completely drained the system, spent ages cleaning the rad and all hoses etc, replaced the suspected head gasket and thought the problem would be sorted.
After running fine for a couple of weeks sludge has started to appear in the header tank again and the engine occasionally runs a little hot before returning to a normal running temp.
Now I am thinking that there was maybe some sludge left in the heater matrix or somewhere which is why it has returned, obviously I am hoping this is the explanation and a couple more flushes over time will sort it.
What I wanted to ask was if there is any other possible source of the sludge as I don't want to keep forking out for antifreeze every time I flush if it is in fact new sludge and not just the remnants of prior to the gasket change.
As always, any advice greatly appreciated......
Cheers
Cheers
