Hey folks,
New to the forum so forgive any ignorance. I've been pulling my hair out for the past week and desperate for assistance.
I bought a W203 C180k M271 and have ran it flawlessly for 6 months. My MAF has been unplugged (as is faulty) the entire time and gives me an extra 3-4 mpg and car was running smoothly.
About 3 weeks ago, just after starting it would idle roughly for about 5 seconds then become normal and I was about to service it with my local mech.
I changed the suspension over to FK street coilovers and drove up to my house again. Fine no problems
Went to sleep and next morning the idle was absolutely terrible. Being an automatic it was undriveable.
It settles itself to idlle on regular jumps between 700 and 1000 in 4/4 time.
What I have done to try and remedy the problem
Replace Crank Breather hose with a temporary large and small hose (sealed) (common fault)
Replaced Camshaft Actuator (a and b) They did have a little oil in the connections
Replaced Camshaft Sensor (which brought up fault so put back in original)
What I have Ordered
New fuel filter (General Service)
New MAF (To get rid of EML)
New coilpack
New spark plugs (General Service)
I can run diagnostics through Torque pro so can read fault codes and get some readings
Current minor faults
p200a (can't find info)
p200b (can't find info)
Has anybody had this issue, would a vacuum leak cause such a big but regular variation?
I can run a smoke test tonight, if so, what vacuum pipe would make a good smoke input)
I'd rather do what I can before I have to fork out for my mechanic to chase his tail.
Any suggestions are welcome and I look forward to having an active contribution on the forums.
(Any vacuum diagrams would also be appreciated)
What I have Ordered
New coilpack
