manual gear mode
tony gee
Cumbria
c class C180 C204
I was on my way home today and thought i'd go manual gear change, got on to a 30mph road and tried to shift into 5th but wouldn't go, just stayed in 4th. is it a speed related thing ? like going faster it will go into 5th ? had a look in my hand book and searched the forum but not found anything. 722.6 by the way.
There will be a minimum speed for each gear
30mph is rather low for 5th?
IIRC the cluster shows D once 5th gear has been selected in manual setting?
As above, you may not have been going fast enough for the transmission to select 5th gear.
What transmission is in the vehicle?
In warmer weather at around 31 on a level surface I could attain 5th gear and let speed drop to 30mph
722.6 here on a C240
When I tried manual mode in the past it would go 1 to 4, but never into 5th. It would just say "D"
Unless it's an AMG 'manual' mode is really only range select, one cannot select gears as in a manual box but limit the the range in which the auto box operates. Select 4th and the box will auto shift from 1 to 4, select 2 only from 1 to 2 etc..
D means all 5 gears are available.
It only shows 1 to 4 in "manual" mode then D means full Auto, ie 1 to 5
just been to pick the Mrs up from work and on the way i got up to 40mph and it clicked straight into 5th gear, but come of the throttle and as it slowed a tad it put its self back into 4th. now i know for sure. 👍
