Manufacturer specific code Sprinter w906
ivandraganov
Anyone that can help,I have P1955 code and won't clear...is it a glow plugs relay?
Two other codes are appearing but manage to clear P0087,2359 and 2208.The van smokes clouds of white smoke when cold..
What are you reading your codes with?
P1955 is a generic Glowpug Relay code, which in MB language is 2545.....see here :- http://www.bba-reman.com/forums/Topic135536.aspx. This ended up being a Throttle position Sensor.
P0087 is Fuel Rail/System Pressure - Too Low, indicating a fuel system problem.
Steve
Steve
Autel ,I think that is injector related,might be wrong as there is white smoke on cold and the van goes in limp mode after 10 min driving.The glow plug relay is ok,the throttle is fine too,checked them off..
Think MAF and fuel pressure values aren’t normal...
