I have fixed another om651 issue in the past with the same fuel rush noise.
The oxygen sensors are detecting too little oxygen in the exhaust and the fuel pump control module is adding more fuel than normal to sustain the proper air/fuel mixture.
In this case was a bad egr diverter vacumm actuator and the egr valve was not closing shut.
And the car had only 1 fault code 0629 - the output of the fuel pump (fuel pump control unit)
The car was running like new after cleaning the egr.
Hope this helps if the it happens again.
