s4mb0
Finding a lot of opinions about if you can use a vacpump or not to suck the old oil out on a oil change on a 2004 E55k w211 Does anyone know the facts or can point me in the right direction. Thanks
If your car is low, nothing but a tray type thingy will fit under it.
The 55k engine has a saddle sump and two drain plugs.
You can only get to one side of the sump with an extractor tube.
Doesn't apply to the OP's E-class 55K, though. Conventional sump, and one drain plug.
I jack mine up under the front central jacking point, block it up like that, and leave it to drain while I change the oil filter. It took exactly 8.5 litres to the full mark from empty.
you might as well consider draining the oil cooler.
is that another bolt or process?
That's the reason i asked. I have seen a lot of people saying you can and a lot saying you can't, the main reason has been mentioned.... Two drain bolts and the fact of not getting all the oil out. So does anyone know a link to or a 100% answer. Guess I'm just being lazy and wanting to change the oil more frequently and easily, but not if its always going to leave excess oil on each suction change.
