Mercedes w123 2.8e relay help
sauliusagintas
Ross On Wye
S320 (W220 LPG converted)
Hi everyone
My W123 is 1978 2.8e. I tried to find fuel pump relay because my car not starting, but no luck until today. I've found 2 relays inside cars dashboard when i was removing all bits from car for restoration project. Witch one is fuel pump relay?
Thanks for answer.
neither of those 2 top is intermintant and second is heated rear window, will have a look for you
On your vintage the fuel pump relay is simply one of the silver square boxes on the drivers side inner wing/ wheel arch area.
