targatopp
Hi I have had a w169 2005 A170 auto for 7 years. The ESP light came on and by switching off the car it reset. This happened a few times over 4 months and when ESP light on it goes into limp which is dangerous. I noticed that the steering wheel was off centre by 26 degrees..probably caused by newer bottom ball joints? which were fitted a year ago.
Yesterday I asked my local mot station to laser track the front wheels which were perfectly in track but steering was 26 degrees out, no tyre wear etc,
They centered steering and then adjusted both track ends whilst I watched and all appeared ok on their machine.
however driving away in less than 100 yds ESP light straight back on. whilst it will reset it keeps coming back on.
my isoft computer tells me steering wheel is centred ok and when I rotate the steering wheel if shows the movement in degrees so is the sensor ok?
a friends star machine shows historic data fault 5C2E inspect wheel and toe and camber we rest all fault codes and it still lights up after 100 yds.
Help!!
should I get the tracking checked elsewhere and also the camber ?
does the steering wheel sensor need to recalibrated by driving but its dangerous at 30 mph in limp?
as far as i know there is no disable ESP button on this carr
is anyone in High Wycombe area that can be recommended or can help?
many thanks
Paul
Help!!
many thanks
Paul
