Also, I assume that when you changed the ignition components, you did choose the correct plugs and gap them correctly for your particular LPG conversion?
(the conversion will specify a plug type and, usually, a smaller gap than standard - this is because LPG is very hard to ignite versus petrol and so, if the gap is left standard, a MUCH higher HT voltage will be required for a spark which WILL accelerate plug, HT lead and coil wear....)
Are your plugs still OK? (8,000 miles at too wide a gap would result in burning and pitting).
