michael8554
Did the EGR bypass about 6 months ago and can report that this has been successful, apart from one issue.
My ML is driven fairly gently around the local country roads, and the turbo can be heard faintly in the background.
If I give it some sustained wellie, like to pass a slow bus on a steep hill, the turbo moan becomes quite loud, which is to be expected.
However, once over the hill and cruising again with little throttle, the turbo can still be heard quite loudly, and only after 10 minutes or so of cruising do I realise it's gone quiet again.
Once things are back to "normal" I can accelerate moderately briskly away from lights without particularly noticing the turbo noise.
I've seen posts where moaning is a symptom of an air leak, but this moan isn't there all the time. About 6 months ago I also replaced the large diameter rubber hose with the male metal connector on the output of the EGR, as this connector was worn and being pushed out under boost.
While it's in its noisy mode, my passengers ask if there's a problem with the engine!
I don't remember this happening before the EGR mod, is this a normal by-product or something else?
Michael
Michael
