ml270 front pads
ripp444
hindhead surey
ml270 2002
could anybody tell me how to remove the pins on the front brakes which hold the pads in place do they just push out with a drift or do they unscrew in some way, as i need to replace mine.
many thanks in advance for any reply.
Use parallel punchers, there's no thread.
I found it easier to just unbolt the caliper.
Saves the pins and caliper too.
i assume if you split the calliper you lose brake fluid and have to re-bleed the brakes.
Thats correct i recently removed the pads in mine to refurb them and a simple tap of a punch/drift pushes the pins out with ease to remove the pads.
