Ml270 limp mode
jay1983
manchester
mercedes ml270 cdi
Well it's finally happened...
After nearly a year of faultless driving it has now gone into permanent limp home mode.
My last service mentioned that the linkage had come off. So looks like am gonna have to do the manifold modification.
Also mentioned in service was the gearbox electrical plug was leaking. Could this cause limp mode?
your egr is most likely clogged up, don't think the plug leaking would cause this.
Pretty sure it's engine. Will only rev to 2500 and is very sluggish between 3rd and 4th. It's like
I have no turbo at all.
You need it plugged in firstly.
I will when I've done the work that needs doin. Feeling the pinch at the moment lol
It's going to be a while until I can get this sorted. Will driving it in limp mode cause any further damage?
limp mode home sends the transmission into 2nd and reverse gears only\
done so to protect the transmission from damage but still allowing you to get to a nearby safepoint,
