Ml320 1999 Drivers Side Brake Caliper Siezed
ADW2002UK
ML320 AUTO
HI FOLKS
DRIVING HOME TONIGHT NOTICED CLUTCH TYPE SMELL PULLED OVER AND DRIVERSIDE FRONT WHEEL WAS SMOKING JACKED IT UP AND COULDN'T TUNR THE WHEEL TRIED TO GET WHEEL OFF TO PRISE THE PISTONS APART LOCKING WHEEL NUT KEY BREAKS GREAT.
HOW DO I KNOW WHAT CODE THE LOCKING NUT IS FOR ONE QUESTION AND TWO WHERE DO I GET NEW CALIPER FROM ANY SUGGESTIONS GUYS WOULD GREATLY BE APPRECIATED THE KEY HAS MB BADGE ON IT SO I ASUME IT WAS THE ORIGINAL ONE WOULD MERCEDES HAVE THESE SORT OF THINGS ON FILE TO GET DUPLICATE ?
OR DO I HAVE TO DRILL OUT OR CHISEL OFF ALL THE LOCKING NUTS AND REPLACE WITH NEW ONES OBVIOUSLY SOME NUMB NUT APPRENTICE HAS GUNNED ON THE LOCKING NUTS THANKS ALOT !
OTHER THAN THIS BEEN WELL CHUFFED WITH MY CAR
CHEERS ALAN:confused:
you need th get the car to your local dealer as they have a full set, they will then get the bolt off for you and you can buy a new key from them.
As for the caliper, best place is Euro Car Parts or GSF.
They Have The Key On File Then Mate Thats Great News Will Have To Get The Offending Wheel Off To Drive It Though As It Is Not Good For Driving At Present My Local Dealer Is In Eastbourne 25 Miles Away Marvelous
Cheers Again
Alan
Will Post Some Pics Of Her Soon
One tip when removing these things, one stamp with the foot is far better than pulling or pushing the lever, its the nearest thing that you can get to an impact spanner
Thanks Guys Guess What I Will Be Doing On My Day Off Seems Like Mission Impossible Where's The Local Wheel Thief When U Need Him Most
Just thinking on this one, as the special socket is broken, ask the MB garage to loosen the others as your broken one will not do it. they have them all in the workshop.
All so well and good if you can get a set the same.
Cheers Gents Will Ring Them First As They Will Probably Have To Order It In First Will They Have It On The History Or Will They Have To See It First ?
Cheers Alan
no what they do is they have a full set in the workshop as often owners have lost their keys. There are only 35 different ones, so they go through them all until they get the right one, then they will order that one in for you..
