Some questions about the P31 Performance pack option on the FL 2012 C63 AMG Estate. Does de P31 pack also have the stiffer sport suspension or is this a separate option from 2012? Besides the fact that this suspension is a little harder, does it also lowers the car more then standard? The C63 AMG I did a test drive with was equipped with the P31 option and it did not feel that hard at all…but I can not compare to a standard C63 without P31 and I'm not 100% sure which suspension the car had?
This is the info I have found about the P31 package… Is this correct?
Do you guys think the P31 is a must have option on a C63 AMG? IMO the front brakes are the biggest difference and selling point. The discs (rotors) of the red calipers are a different composite material that is better for heat management. Is the braking force the same as the standard “grey” brakes? Will you notice the difference between the two brakes on the street…?
Or is it only in more extreme situations that the red P31 brakes will be less prone for overheating/fading? I will not drive this car on track, but good brakes is something I find very important on cars (I fitted full AP racing brakes on my other car).
The 487hp from the P31 package is also something that is not so important to me… When you get the car chipped by Eurocharged it will even have more power then the P31.
I was thinking about searching a C63 AMG estate with the following options and P31 is not on my essential wish list. What are your opinions?
- Black exterior color
- Silver 19” spoke wheels- Black interior
- Black leather interior trim (or fitment aftermarket)
- Xenon lights
- Tinted windows rear
- Command online navigation
- Harman Kardon Sound (important for me)
- Media interface for iPod (or fitment aftermarket)
- Heated seats
- Seats with memory
- Auto closing rear trunk / Easy Pack
- Parking Sensors / Parktronic
- Mirror package
- Diff would be nice (or fitment of aftermarket Quaife diff)
P30 and P31 are different. P30 had a limited-slip differential and a stiffer suspension. P31 had neither of those, but a stronger engine. Stronger in terms of 30 extra HP and some beefier engine components.
They both have lighter brakes (2-piece rotors), increased top-speed limit (174 MPH vs. 155 MPH) and cosmetics like Alcantara steering wheel.
The extra power in the P31 is definitely noticeable and the lighter brakes reduce unsprung weight so improve handling a little. But the most important of any of these might be the LSD, which is not part of P31. It's an extra-cost option and many P31s had it, but some didn't and some non-P31s had it as well. If I had to choose, I'd probably take a non-P31 with LSD over a P31 without it. The best is both.
There are a lot of improvements in the 2012 and later "facelift" models. They have a better transmission and improved suspension. I'd take a base 2012 with MCT over 2011 P31, especially if the 2012 had an LSD and the 2011 didn't.
I'd avoid a P30. Most people found the suspension too firm and uncomfortable. They dropped that suspension in the P31. No C63 has a soft suspension.
- Xenon lights
- Heated seats
- Seats with memory
- Mirror package
