Uncle Fester
This weekend I did an oil and filter change, my first time on this car (or any other MB for that matter)
Having never done it before it took me a little longer than normal, as I had to get accuainted with getting the covers off.
The car is quite low to the ground so I needed to jack it up to get under to remove the two bottom covers, to gain access to the sump drain plug (10 screws/bolts in total) although now that I know where they are, this may not be necarsary.
Drained out oil and removed filter cap (special tool required for this, which I didn't have, so I improvised)
I would recommend the purchase of the filter removal tool to make the job easier and I will be sourcing this for the next time.
The oil filter is located at the front, top of the engine, and is very easy to get to.
The hand book stated that the car needs 6.5 litres of oil including filter(although only 5 litres drained out) whereas the Haynes manual stated 7 litres, so I put 6.75 litres in.
I had a couple of other things to sort out (leaking washer bottle and wheel arch liner that got damaged from hitting debris on the motorway) so did them at the same time.
I also checked the brake pads and discs for wear, but they were fine.
The only niggles with servicing this car were getting the engine covers off the top and bottom (obviously the bottom ones are much easier if you have a lift ) but other than that it was as straight forward as any other car really. (except Nissan who put oil filter underneath the inlet manifold!)
Also the oil drain plug reuires only a 13mm socket to remove it, no special tools.
Since changing the oil I have twice had a waring "reduce oil level" on 2 separate journies, but only whilst on the motorway and not a consistant thing, and nothing shows at idle or rving in any other situation.
So I guess the MB handbook was correct at 6.5 litres.
I did notice a "ticking" injector at idle, and have put some "redex" in the tank in the hope that it may help, any advivce would be appreciated.
So all in all I had a productive day, and learned a bit about the car that I drive.
