shaze30
- Nov 30, 2014
- sl500/c43 amg
Mate you have really inspired me to get on with my c43 by reading this thread
Well done pal
Excellent work
Well done pal
Excellent work
Justin, as so many others have already said, this has been a fabulous project and thread. Having just started my C43 ownership, I think that if I can achieve half of what you have, I'll be happy!
Well done pal
Excellent work
Hi Justin How are you doing?
Regarding the rear diff are you fitting the LSD to your original 43 Diff? Or are you going to attempt to fit the 55 Diff? If you did you would have done exactly what AMG did when they did the 202 55 special, and would make your car even more desirable IMO.
If you haven't already get yourself an agreed value insurance policy, after all the hard work you have put into it, it would be heart breaking if anything happened to it. I know after losing my C43/55 202 recently I was totally gutted though I did put a lot of work into it over the years not as much as you have. Your car has to be worth 5 figures minimum now possibly more as it is such a sorted car.
Hi Andy,
I would probably get a W210 E55 diff and fit the LSD kit to that. As you say will keep it all matching and keep my car on the road while the diff is being built up
Will sort out a agreed valve when it is due up fairly soon
are you cutting floorpan in the back to fit the new diff?
E55 housing seems to be a bit larger than c43 housing
No, if it is bigger then I won't bother. I'll use the original diff
that's what AMG had to do on w202 C55 they cut the floorpan to fit the larger style diff
^^ he just said that
Tony.
