However , yesterday , just to see what it would do , and alone in the car , on a straight and clear stretch of road I floored it from about 40mph : it kicked down to 2nd and took off rapidly , with 90 mph coming up very quickly before I backed off . Worryingly , there was an alarming and very loud thump from the back when I did this - so I will need to look at propshaft couplings , subframe bushes etc . However , it doesn't happen in normal driving so I will just resume my normal sensible driving for now .
The saga continues .
If i remember correctly, the seat illumination is from a twist on lamp that doesn't have separate wiring.
And cover the high beam light too. When you go to sort out the stereo, I'll talk you through the taking it apart procedure. It's quite straightforward bit there are lots of bolts. Gotta love the hydraulic lines for the roof in the second pic
The SRS bulb may well be burnt out or missing. Common fault for the SRS light on was evidently a dodgy connection to the seat occupancy sensor under the seat or possibly one of the seat belt buckle sensors. Both cases there's probably a bodge fix to fool the system. Dodgy steering wheel airbag squib electricals is another possibility
The Alpine pulled out easily enough , but instead of the now almost universal ISO connectors ( which I'm sure I had read somewhere R129's were equipped with ) I found every installer's nightmare : a mess of cut wires , bullet connectors and insulating tape![]()
I feel your pain Derek, I started to strip out the non working after market alarm system on the weekend.
I was being painstaking careful, checking which wires went where, taking one out, starting the engine etc.
Anyway I cut one wire, engine would not start , GRRRR
Anyway, followed it to the fuel pump relay, and it was a switch to cut the fuel pump to immobilise the car, took me over an hour to find it.
The amount of 90's after market stuff, phone, alarm etc, was unreal. I even found a siren behind the centre console, none of it worked.
Have fun tonight![]()
