And Some after pics. First job was to fill that hole and clean up under the ABS.
Front Cowl now painted - hole underneath the ABS bracket now properly filled, primed, seam sealer applied, primed again and finally four coats of paint.
The corner where the bracket, inner wing and chassis leg meets is where the hole ended. You can also see I've tapped another hole through to allow water to drain otherwise there is nowhere for the water to go - it just sits in a nice little bath (my suspicion is that Merc didn't think of this when they added the ABS bracket to later cars).
Underneath the ABS pump all nice now. In the foreground you can see the drain hole nice and clear now. That hole is now all treated and restored too!
Here you can see the ABS pump clean up(haven't put the cover on it yet), along with the area under the pump nice and clean. Also painted the brackets black so it looks a bit fresher.
and another
Rust removed from the bracket that holds the water bottle, and decided to paint the expansion tank bracket red to fit in a bit nicer .
All the brake lines have been clipped back together - those dampers are a right pain to fit, and even harder is getting tape around them afterwards!
After this, the master cylinder was put back in.... and the last most easily accessible brake line into it cross threaded. I think the actual threaded nut has stretched. Unfortunately the threads on the master cylinder are stripped, so a new one is on order before I can bleed the whole system and check whether everything works. I'll need to cut the nut off and replace also.
I've also refurbed the front fog lights and cross brace at the same time - pics to follow!
