westy2005
Hi Guys,
just looking for a bit of help with the above. Up until recently all was working fine but overnight the bulb error came on the dash - simples - change the bulb as it was not lighting up - but this did not resolve the issue. So i changed the bulb that was working to the side that is not and still it did not light up after a bit of playing around it looks like a fault with the brown wire that goes to the n/s bulb, and this is where i get stuck.
Also to add to this the dash is now saying that there are numerous bulb faults i.e 2 squares on the display - but all other remaining bulbs work as they should.
If if run a wire over from the O/S plate bulb to the offending connector it lights up.
where do i investigate next???
many thanks
many thanks
