miggit
We'll I'm in a bit of a pickle, my very long in the tooth ML270CDI is about to self destruct and I need to replace it.
So I was going to get a ML320cdi. And then I found out that they do NOT have a low range gearbox, D'OH!!
I tow Event Toilets about, so I need something that has a bit of grunt behind it, especially off road. So I hit Autotrader and have come to the only conclusion that a Jeep Grand Cherokee CRD will do what I need....
BUT, it's a Jeep, but it does have the Mercedes V6 CDi engine and I assume a Mercedes gearbox... so how bad can it be??
There is a lot of talk about injectors failing at around the 100k mark due to multiple firing at tickover to reduce diesel knock.. is this a Jeep thing or Mercedes thing?
I have also seen a bit about failing oil coolers, again is this common and how easy is it to do... yourself did I really just say that, Oh dear
And I've also been warned that they can suffer from backdeath... But that doesn't worry me, I can sniff out backdeath from 20 paces, I just haven't mastered getting the injectors to stay put in my worn out head.
I've been looking at a Jeep that's got 104k described as slightly smokey engine, and is at a price that I can afford to pack it off to my local Bosch Diesel Centre and have them pluck the injectors and repair as needed, gaining 6 good injectors and new seals without getting my hands dirty
So assuming that I can't detect backdeath, am I on to a solution or a one way trip to the fun farm?
Oh and I'm open to suggestions on cars.. just not a Range Rover... Had one, it ate recon gearboxes at the rate of 21k.. and a Discovery looks good until you see the lists of common faults... Land Rovers have never had good wiring, and the newer they get the more there is to go wrong, and it does!
Need something rated at 3.5 ton towing capacity and around 30 MPG when not towing, and it needs a proper low range gearbox!
